Skip to main content
Lesson 2: Drive to Number ‘1’
  • Now the VR Robot will drive back to the number ‘1.’
    L2_x-axis-go-to-5-with-arrows02
  • To navigate the VR Robot back to the number ‘1,’ remove the [Stop driving] block and replace it with the following blocks.
    remove-stop,-add-return-to-1
  • Note that the second [Wait until] block contains a <Less than> Boolean block instead of a <Greater than> block. This is because the VR Robot is now driving down the X axis and the numbers are becoming more negative. The VR Robot will stop once the X-values are LESS than -900.
    call-out-the-less-than
  • Launch the Number Grid Map Playground if it is not already open and run the project.
  • Watch the VR Robot drive to number ‘1’ on the Number Grid Map Playground.
  • In this project, the VR Robot drives to the number ‘1’ on the Number Grid Map Playground. Since the X-values are decreasing as the VR Robot drives to the number ‘1,’ the project uses a <Less than> block.
  • The VR Robot will stop once its X-value is less than the X-value of the coordinate that the indicated number is on. Since the X-value of the number ‘1’ is -900, the VR Robot will stop driving once the X-value is less than -900.
project-flow-unit-6-lesson-2-part-2
For Your Information
A [Wait] block will pause the project's flow for a specific period of time in seconds before moving on to the next block in the stack. A [Wait] block can be used to help observe individual behaviors in your project that may run quickly together, such as moving between two different locations on a Playground.
wait-block
Select the Next button to continue with the rest of this Lesson.
