Arrive At The Red Square
Use [Drive for] and [Turn for] blocks to code the VR Robot to drive from the Start Position (green square) to the End Position (red square) on the Maze+ Playground.
- Select the Wall Maze+ Playground.
- Download the .vrmaze file from this folder and upload the maze in the Playground.
- For help with uploading and downloading mazes in the Wall Maze + Playground, see this article.
- Code the VR Robot to drive from the Start Position (green square) to the End Position (red square).
- Put the instructions in the right order to complete the task successfully.
Helpful Hints
- The distance across one maze square is 300mm.
- Use the drive for block from the Drivetrain category to move the Drivetrain for a given distance.
- Matching Python command:
- Use the turn for block from the Drivetrain category to rotate the Drivetrain for a given angle.
