Skip to main content
VIQRC Virtual Skills - Slapshot
Knock The Dispensers
Use [Drive for], [Turn for], and [Spin for] blocks to code the Hero Bot to drive to a blue Dispenser, remove all the Discs from the blue Dispenser, drive to the yellow Dispenser, and remove all the Discs from the yellow Dispenser.
  • Select the VIQC Virtual Skills - Slapshot Playground.
  • Drive the Hero Bot to a blue Dispenser.
  • Code the Hero Bot to spin the Arm Motor to raise the Arm to release the Discs from the blue Dispenser.
  • Drive the Hero Bot to the yellow Dispenser.
  • Code the Hero Bot to spin the Arm Motor to raise the Arm to release the Discs from the yellow Dispenser.
Helpful Hints
  • Each full tile on the VIQC Virtual Skills Field is 300mm by 300mm.
  • Use the spin ArmMotor block from the Motion category and select the forward direction to raise the Arm.
    Arm motor forward 90 degrees block
    • Matching Python command:
      Arm motor forward 90 degrees Python command
  • Use the spin ArmMotor block from the Motion category and select the reverse direction to lower the Arm.
    Arm motor reverse 90 degrees block
      Arm motor reverse 90 degrees Python command
