Skip to main content
Removing Connectors from Beams and Plates
Using a pitch shaft to remove a corner connector
How to Easily Remove Connectors
You can easily remove corner connectors from beams or plates by placing a metal shaft through one of the holes of the corner connector and pulling outward while holding down the beam or plate.
