Skip to main content
STEMLabs IQ
Lab 12 - M.A.D. Box
Calculating Three Gear Ratios
Now that you have calculated a compound gear ratio from two gear ratios, we will now calculate a compound gear ratio from three gear ratios!
You will work in groups of four to calculate gear ratios and determine the resulting mechanical advantage.
Calculation 2
Fill in the missing calculations from the Gear Ratio table. Keep in mind, each person should be calculating according to their role.
  • Role 1: Calculate the Gear Ratio 1 row of the above table. Show all work in your engineering notebook.
  • Role 2: Calculate the Gear Ratio 2 row of the above table. Show all work in your engineering notebook.
  • Role 3: Calculate the Gear Ratio 3 row of the above table. Show all work in your engineering notebook.
  • Role 4: Calculate the Resulting Ratio row of the above table. Check the calculations from Gear Ratio 1, 2, and 3 before calculating the final compound gear ratio. Show all work in your engineering notebook.
  • All Roles: Calculate the Advantage row of the above table. Show all work in your engineering notebook.
Calculation 3
