Skip to main content
A Diagram Showing a Pitch Shaft Being Used to Easily Remove a Corner Connector From a Structural Plate
Using a pitch shaft to remove a corner connector
How to Easily Remove Connectors
You can easily remove corner connectors from beams or plates by placing a metal shaft through one of the holes of the corner connector and pulling outward while holding down the beam or plate.
