Skip to main content
Removing Standoffs from Mini Standoff Connectors
A Diagram Showing a Shaft Being Pushed Through a Mini Standoff Connector to Remove a Standoff
Removal of a standoff from a Mini Standoff Connector
How to Easily Remove Parts from Mini Standoff Connectors
Standoffs and Mini Standoff Connectors can be separated by pushing a shaft through the Mini Standoff Connector. The same technique can be used for parts with similar ends in Mini Standoff Connectors, such as pins.
