Skip to main content
STEMLabs IQ
Lab 10 - Tallest Tower
Set up the Earthquake Platform
Connecting the Earthquake Platform
The VEX Earthquake Platform Connected to a VEX IQ Robot Brain
The Builder should check that the Earthquake Platform is ready with a charged battery and that the Smart Motor is properly connected to Port 1 on the VEX IQ Robot Brain.
Powering on your Robot Brain
A VEX IQ Robot Brain With a Circle Around the Check Mark Button (Top Right Button On Brain)
A powered off Robot Brain screen
The Tester can now operate the Robot Brain and press the Check button to power on the Robot Brain.
Opening the Settings menu
The Settings Screen Opened on the VEX IQ Robot Brain
The top-level Settings menu
Press the X button until you arrive at the Settings menu.
Opening the Device Info Menu
The Settings Screen Opened on the VEX IQ Robot Brain With the 'Device Info' Option Selected
The Device Info option
Use the arrow buttons to navigate down to the 'Device Info' selection on the Settings menu and press the Check button.
Viewing a Connected Smart Device
The Device Info Screen Opened on the VEX IQ Robot Brain Displaying Information About the 'Port 1 Motor' With a Message at the Bottom Saying 'Press <Check Mark Button> Starts Motor'
The Device Menu for Port 1 with a Smart Motor connected
You can use the up and down arrows to navigate through the Smart Devices that you have connected.
Activating the Motor
The Device Info Screen Opened on the VEX IQ Robot Brain After Starting the Motor, Displaying Information About the 'Port 1 Motor' With a Message at the Bottom Saying 'Press <Check Mark Button> Stops Motor'
The Tester should press the Check button again to activate the motor. Press X to stop it at any time, and press the Check button again to restart it.
