Skip to main content
STEMLabs V5
Clawbot With Controller Student
Remix Questions-Blocks-based
Answer the following questions in your engineering notebook after completing the three activities.
  1. The [Set motor] block is set to “hold” for both the Arm Motor and the Claw Motor. What would happen if those blocks were removed?
  2. The [Spin] and [Stop] blocks that control the Arm and Claw Motors are nearly identical. If you were to create this project yourself, how could you save time and avoid dragging every individual block into the workspace over and over?
