Skip to main content
STEM Labs
It's a Draw! Teacher
Teacher Portal
  • 12-18 years old
  • 410 minutes
  • Beginner
Preview image
Description
Students will explore the VEX V5 Clawbot and using it as an artistic tool in a drawing game.
Key Concepts
  • Developing new ways of thinking, seeing, and creating.
  • Investigate what it means to be an artist and create drawings.
  • Use creativity to play and succeed in a competitive drawing game.
Objectives
  • Apply building directions to create a robot to complete a specific task.
  • Create illustrations to describe specific vocabulary words.
  • Analyze connections between text and real life objects/shapes.
Materials needed
  • 1 or more VEX V5 Classroom Starter Kits
  • Large sheets of paper or poster board, or a large dry-erase board
  • Black marker or dry-erase marker (Permanent marker not recommended)
  • Engineering notebook
  • Tape
  • Timer or Stopwatch
  • Printed It's A Draw cards (Google Doc / .pdf)
Facilitation Notes
  • Ensure all required parts for the build are available prior to starting this STEM Lab.
  • Make sure there is ample space to lay the paper down that the robot will drive over during it's drawing. Taping the taper down in helpful.
  • The teacher can create additional cards as needed for the game.
  • An engineering notebook can be as simple as lined paper within a folder or binder. The notebook shown is a more sophisticated example that is available through VEX Robotics.
  • When drawing with the robot, make sure the flooring under the drawing page is protected.
  • Avoid using permanent markers when drawing with the robot.
  • The approximate pacing of each section of the Stem Lab is as follows: Seek- 240 minutes, Play- 60 minutes, Apply- 30 minutes, Rethink- 120 minutes, Know- 30 minutes.
Further Your Learning
Math
  • Students can create new cards with additional math terms that can be used in the game.
English
  • Conduct additional research on how robotics is influencing art and write a paragraph about it.
Educational Standards
Standards for Technological Literacy (STL)
  • 1.G
  • 1.H
  • 3.F
  • 8.F
Next Generation Science Standards (NGSS)
  • HS-ETS1-2
  • HS-ETS1-3
Common Core State Standards (CCSS)
  • MP.1
  • MP.5
