Skip to main content
Design, Develop, and Iterate on your Project - Text-based
Answer the following questions in your engineering notebook as you design your project.
  1. What do you want the project to have the robot do? Explain with details.
  2. What steps will you follow to test the project? Explain with details.
  3. How can your robot be programmed to complete the task more efficiently? Explain how.
Follow the steps below as you create your project:
  1. Plan out the path you want to program your robot to take using drawings and pseudocode.
  2. Use the pseudocode you created to develop your project using text.
  3. Test your project often and iterate on it using what you learned from your testing
If you're having trouble getting started, review the Example Projects within VEXcode V5:
examples
