Skip to main content
STEMLabs V5
Speedy Delivery Teacher
Teacher Portal
Speedy Delivery Preview
  • 12-18 years old
  • 45 minutes - 5 hours, 45 minutes
  • Intermediate
Preview image
Description
Students are asked to program a robot to navigate a warehouse and to prepare packages for delivery.
Key Concepts
  • Programming
  • Robot Behaviors
  • Iterative Design
Objectives
  • Apply building directions to create a robot to complete a specific task.
  • Decompose problems into smaller components through systematic analysis, using constructs such as procedures, modules, and/or objects.
  • Differentiate between the commands Drive Forward and Drive in Reverse, Turn Left and Turn Right, Arm Up and Arm Down, Open Claw and Close Claw.
  • Utilize the Arm Up and Arm Down, Open Claw and Close Claw commands in an project-based activity.
  • Explain why advances in robotic development is leading to more precise movements.
Materials needed
  • 1 or more VEX V5 Classroom Starter Kits
  • Roll of tape
  • 12 x 12 foot or 3.66 x 3.66 m open area
  • Optional: VEX Robotics Competition Field Perimeter and Tile kits.
  • Meter stick or Ruler
  • Engineering Notebook
  • Aluminum cans
  • Boxes of various sizes
  • 9+ textbooks
  • Stopwatch
  • VEXcode V5
What You'll Need to Know
  • Programming Forward and in Reverse
  • Programming Turning Right and Turning Left
Facilitation Notes
  • Ensure all required parts for the build are available prior to starting this STEM Lab.
  • Make sure that there is ample space in the classroom to measure and tape the layout of the "warehouse" that will be used in the activity. If you have a VRC Field Perimeter and Tile kit, you may set up the Package Dash Challenge using it. If not, tape can be used to outline the measurements.
  • If multiple students will be downloading their saved projects to the same robot, have the students add their initials to the name of the saved project (For example, "Forward and Backward_MW). This way students can find and make adjustments to their projects and not others.
  • An engineering notebook can be as simple as lined paper within a folder or binder. The notebook shown is a more sophisticated example that is available through VEX Robotics.
  • Students can share their pseudocode with the teacher for feedback prior to creating the project for feedback.
  • Students can create and expand on the warehouse floor plan to explore different programming options.
  • The approximate pacing of each section of the Stem Lab is as follows: Seek- 155 minutes, Play- 70 minutes, Apply- 15 minutes, Rethink- 105 minutes, Know- 5 minutes.
Further Your Learning
English/Debate
  • Discuss the pros and cons of robots completing more job related tasks as technology develops.
  • Research and write about other areas where robotic precision is being developed or should be explored.
History
  • Write a paragraph or create a timeline sharing the highlights of industrial robotic development from 1954 until present day.
Educational Standards
Standards for Technological Literacy (STL)
  • 1.F
  • 6.D
Next Generation Science Standards (NGSS)
  • HS-ETS1-2
Computer Science Teachers Association (CSTA)
  • 3A-AP-17
  • 3A-AP-21
  • 2-AP-19
  • 3A-IC-24
Common Core State Standards (CCSS)
  • RST.9-10.2
  • RST.9-10.3
  • MP.5
  • MP.6
TEKS
  • 126.40.c.5.A
  • 126.40.c.5.B
  • 126.40.c.3.A
  • 126.40.c.3.B
  • 126.40.c.3.F
  • 126.40.c.3.G
  • 111.39.c.1.C
