Skip to main content
In order to successfully complete this STEM Lab, you'll need to know how to program the robot to move forward, in reverse, left and right before getting started. You can use the links to other STEM Labs below or the Example Projects in VEXcode V5 to learn how to drive and turn the robot before proceeding.
Basic Movements
Image of the file menu open in VEXcode V5 with Open Examples highlighted
If you have not programmed your robot to drive or turn before, make sure to complete each with your robot before moving on!
