Using the Vision Sensor - Text-based
Teacher Toolbox
The Purpose of this Activity
Using the Vision Sensor effectively requires the students to be able to configure it and tune it depending on the environment that it is in. In the following activity, the students will learn how to do both.
For more information about programming the Vision Sensor with VEXcode V5, visit the help information for C++ or Python within the VEX Library.
The following is an outline of what your students will do in this activity:
Open the Detecting Objects (Vision) example project.
Configure the Vision Sensor.
Run the Detecting Objects (Vision) example project.
Discuss and Reflect.
Tune the Vision Sensor.
Teacher Tips
If this is the student's first time using VEXcode V5, they can access may help articles in the VEX Library.
Teacher Tips
Using Autocomplete
Autocomplete is a feature in VEXcode V5 that predicts the rest of the command you are typing. As students are working in VEXcode V5, encourage them to use the Autocomplete feature to help with the syntax.
The Autocomplete articles for C++ or Python cover how to use the Autocomplete feature. For more information, explore the tutorial videos within VEXcode V5.
Get the hardware required, your engineering notebook, and open VEXcode V5.
Quantity | Materials Needed |
1 |
VEX V5 Classroom Starter Kit |
1 |
VEXcode V5 (latest version, Windows, MacOS) |
1 |
Engineering Notebook |
1 |
Configuring a Vision Sensor (Tutorial) |
1 |
Tuning the Vision Sensor (Tutorial) |
1 |
Detecting Objects (Vision) example project |
VEXcode V5 contains many different example projects. You’ll use one of them in this exploration. For help and tips on using example projects click here(C++ or Python).
Complete the following steps:
Open the File menu.
Select Open Examples.
Select and open the Detecting Objects (Vision) example project.
Save your project as Detecting Objects.
Check to make sure the project name Detecting Objects is now in the window in the center of the toolbar.
For addition help in opening an example project, click here.
Teacher Tips
Make sure that the students have selected Open Examples from the File menu.
Make sure that the students have selected the Detecting Objects (Vision) Example project. You can point out to students that there are several selections to choose from on the Open Examples page. Remind students that they can refer to the Knowledge Base articles as any time.
You can ask students to add their initials or the name of their group to the project name. This will help differentiate the programs if you ask the students to submit them.
Since VEXcode V5 has autosave, there is no need to save the project again after it has been saved for the first time.
If students need help saving, direct them to the Naming and Saving Your Project tutorial.
Begin by reading Vision Sensor - Robot Config - VEXcode V5.
Then, read Vision Sensor Adjustments-Robot Config-VEXcode V5
Next, configure the Vision Sensor for three colored objects: red, green, and blue.
Open the previously saved Detecting Objects (Vision) example project.
How is the Vision Sensor being used in this project? Predict what will happen when the project is run and write down the predictions in your engineering notebook.
Teacher Tips
The three colored objects do not have to be cubes, they can be any relatively small green, red, and blue object.
Motivate Discussion
Answers
Facilitate a classroom discussion to have the students share what they predicted this project will do in their engineering notebook and also reflect on how to configure the Vision Sensor.
Facilitate the discussion by asking the following questions:
What are the steps for configuring the Vision Sensor?
What does the if then else structure do?
What would happen to how the Vision Sensor detects objects if we changed rooms?
Answers will vary:
The students should note that the object name will have to be decided. The object should be placed in the frame of the Vision Sensor and stilled using the "Freeze" button. The color will then be selected and configured using the "Set" button. The students should outline the steps listed in this article as well as the steps listed in the Configuring a Vision Sensor tutorial video.
The if then else structure runs the instructions inside the first or second parts of the if then else based on the Boolean value reported. More information on how to use this instruction can be found in the Help information.
If the Vision Sensor was asked to detect objects in a different environment, the lighting could change and the colors of the objects could look different. This may make it difficult for the Vision Sensor to detect objects.
Often times an object is configured to be recognized by the Vision Sensor in one environment, for example, in a classroom. When the Vision Sensor is then taken into a different environment such as a competition setting, the object may not be recognized by the Vision Sensor. This is often due to a change in lighting after the Vision Sensor has already been configured. To solve this problem, you may have to tune your Vision Sensor.
Begin by watching the Tuning the Vision Sensor tutorial video.
Next, adjust the Vision Sensor for the three colored objects: red, green, and blue.
How will tuning the Vision Sensor affect how well it can detect objects? Take the Clawbot to a different part of the room with more or less light.
Download and Run(C++ or Python) the project. Place different colored objects in front of the Vision Sensor and observe the robot's behavior. Document in your engineering notebook how well the Vision Sensor detects objects. Does the Vision Sensor need tuned after it changed locations?
Tune the Vision Sensor as necessary. Test the Vision Sensor after it has been tuned to determine if it can detect objects better and make adjustments as needed.
Motivate Discussion
Reflecting on the Activity
Q: Did the Vision Sensor detect objects as you expected it to?
A: Answers will vary; however, the goal of this question is to promote cognitive thinking. Students should note that the Vision Sensor's ability to detect objects can change depending on the environment and light.
Q: Why is it important to be able to tune the Vision Sensor as needed?
A: While answers may vary, a common response should be that if a robot uses a Vision Sensor and is taken to a competition or even used in a game or challenge, how well the robot performs will depend on the accuracy of the Vision Sensor. Tuning it is important for accuracy.
Extend Your Learning
Multiple Objects
Ask the students to run the Detecting Objects project and place more than one of the configured objects in front of the Vision Sensor. What happens? Ask them to document their findings in their engineering notebook.
Now, ask the students to place one configured object and one unknown or not configured object in front of the Vision Sensor. What happens? Ask them to document their findings in their engineering notebook.
Ask the students before testing it, what would happen if they placed three configured objects in front of the Vision Sensor? Ask the students to write down their predictions before testing it. Ask them to record their observations after testing it.
Facilitate a discussion on what the students predicted and observed.
Facilitate the discussion by asking:
What were the differences between one, two, and three objects?
Would you adjust the project in any way for recognizing multiple objects?
