Vision Sensor Preview
- 12 - 18 years old
- 45 minutes - 4 hrs, 40 min
- Beginner
Description
Students are asked to build and utilize a robot that will detect objects using color signatures.
Key Concepts
Using the Vision Utility
Configuring the Vision Sensor
Tuning the Vision Sensor
Identifying Sensing Blocks/Instructions Used to Program the Vision Sensor
Objectives
Follow building instructions to create a robot that will complete a specific task.
Identify that an image from the Vision Sensor can be captured and that image will be processed and analyzed for color signatures.
Identify the steps needed to configure the Vision Sensor to detect an object.
Construct and arrange ideas in an engineering notebook.
Identify the criteria and constraints of the solution for their design problem by considering lighting constraints.
Explain the advantages of using robots for transportation on highways and transit networks.
Explain the use of "Object Exists" as a condition in an if/then/else structure.
Materials needed
1 or more VEX V5 Classroom Super Kits
Optional: VEX V5 Classroom Starter Kit + Vision Sensor + Mounting Hardware
Green, blue and red solid objects
VEXcode V5
Engineering notebook
Facilitation Notes
Ensure all required parts for the build are available prior to starting this STEM Lab.
Students will need to download an example project with either Blocks-based or Text-based VEXcode V5 and configure color signatures in the lighting conditions for the classroom area. There are directions for both of these actions provided in the STEM Lab.
Due to varying lighting conditions, the Vision Sensor may need to be tuned after configuring the color signatures.
An engineering notebook can be as simple as lined paper within a folder or binder. The notebook shown is a more sophisticated example that is available through VEX Robotics.
The approximate pacing of each section of the Stem Lab is as follows: Seek- 155 minutes, Play- 45 minutes, Apply- 15 minutes, Rethink- 60 minutes, Know- 5 minutes.
Further Your Learning
Science
Research and debate the pros vs. cons of self-driving cars. Discussion can be focused on safety, efficiency, and/or design.
Investigate and write a paragraph about GPS (Global Positioning System) or LIDAR, the two systems that are necessary for self-driving cars.
Social Studies
Discuss and compare what types of landforms or communities that would be the easiest or hardest to implement a self-driving car and explain why.
English
Write a persuasive piece on the need for self-driving cars in the 21st century.
Create a brochure advertising a new self-driving car that has been designed by the student. Include a picture, sales information, price, and any other marketing information to promote the vehicle.
Educational Standards
Computer Science Teachers Association (CSTA)
3B-AP-08: Describe how artificial intelligence drives many software and physical systems.
Common Core State Standards (CCSS)
CCSS.ELA-LITERACY.RST.9-10.3 follow precisely a complex multistep procedure when carrying out experiments, taking measurements, or performing technical tasks, attending to special cases or exceptions defined in the text.
CCSS.ELA-LITERACY.RST.11-12.3: follow precisely a complex multistep procedure when carrying out experiments, taking measurements, or performing technical tasks; analyze the specific results based on explanations in the text.
CCSS.ELA-LITERACY.RST.11-12.9: Synthesize information from a range of sources (e.g., texts, experiments, simulations) into a coherent understanding of a process, phenomenon, or concept, resolving conflicting information when possible.
MP.5: Use appropriate tools strategically (Rethink)
MP.6: Attend to precision (Seek, Play, and Rethink)
