Skip to main content
Teacher Portal
Answer Key
Summative Assessment Answer Key
  1. Which of these is the best description of how My Blocks are used in a VEXcode V5 project?
    To create a sequence of blocks that can be used multiple times throughout a project.
  2. Based on this output, what color disk does the Optical Sensor detect?
    Red.
  3. TRUE or FALSE: Based on this image, the Line Tracker will return a low value.
    False
  4. What triggers the exit conveyor motor to stop running in this code snippet?
    Exit Sensor reports a value greater than 20%.
  5. What type of value does the Line Tracker return?
    Percentage values from 0 to 100%.
