Record Sensor Values
Teacher Toolbox
Facilitating the Record Sensor Values Page
What the Teacher Will Do:
- Instruct students that they will be working together in their groups to follow the steps on this page.
- Circle the classroom as students work through these steps and answer any questions that arise.
- As groups check in, ensure they have built their project correctly before moving on. Guidance for this check in is provided in a Teacher Toolbox at the bottom of this page.
In this Lab, the Optical Sensor as well as three Line Trackers are used to trigger different movements of the conveyors. To be able to code the sensors, you need to gain a better understanding of the Line Trackers. This better understanding includes their limits and outputs in order to record the upper and lower threshold values that will be used in your project.
The outputs of the Line Trackers are the percentage of light that is being reflected back from the Line Tracker. There is a high and low threshold value with the Line Trackers.
If there is no object in front of the sensor, there is nothing for the light to reflect off of and thus, no light is detected as received. This would produce a low value, anywhere from 0 - 12% depending on the amount of light in the environment. In this project, when there is no disk in front of the sensor, a low value will be reported.
If there is an object in front of the sensor, there is something for the light to reflect off of and thus, light is detected as being received. This would produce a higher value, anywhere from 12% or higher, depending on how close that object is to the sensor. In this project, when there is a disk in front of the sensor, the value will spike and a higher value will be reported.
These threshold values can be used to code the sensors to trigger certain movements of the conveyors, diverter, and the arm. Once the sensor detects a value above or below a threshold value, the conveyors can be triggered to stop or begin moving. You will need to record the high and low value for each of the three Line Trackers on the Workcell to use in your project.
Download and run the project and then view the Brain's screen.
The coordinates of the arm, the values of the Line Trackers, and the values of the Optical Sensor are displayed.
The first group of values to be displayed are the arm's x, y, and z-coordinates. This will be used in the Lab to obtain the pick up and drop off locations for the green disk.
The second group of values to be displayed is if a disk is detected by the Optical Sensor and if so, what color the disk is (red, blue, or green).
Place a red disk in front of the Optical Sensor. Notice that the ‘Disk Detect’ value reports ‘TRUE’ and R for ‘Red’ also reports ‘TRUE.’ Once you have seen 'R: TRUE,' remove the red disk from in front of the sensor.
Only one of the three colors can report ‘TRUE’ at one time. Thus, when detecting a disk, one color should be ‘TRUE’ and the two other colors should report ‘FALSE.’
The third values to be displayed are the outputs of the Line Trackers. Each of the three Line Trackers can display different values.
This can depend on different conditions such as how close the disk is to the sensor or the amount of light in the environment.
Ensure there are no disks in front of the Load, Pickup, and Exit sensors and record the three low values in your engineering notebook.
These low values will be used later in the Play section when you further edit your project.
Record your sensor values and not the ones shown in this image.
The Line Tracker value will report as a higher reflectivity value when a disk is in front of the sensor.
Place one disk in front of each of the three Line Trackers to see how the value increases when there is a disk present.
Record these three high values in your engineering notebook.
Once you have recorded all three high values, stop the project.
Teacher Toolbox
Troubleshooting
If groups are having issues with their project to determine the Line Tracker threshold values, have students check their 3-wire cables.
- Ensure that the cables are fully inserted into the Brain.
- Check that all 3-wire extension cables are fully connected and plugged in so they both have the same color orientation.
- Also remind students that these values also are reliant on the surrounding environment. Someone standing too close to the Workcell or a bright classroom can change the values.
- Encourage students to experiment with the placement of the disks on the conveyors in front of the Line Tracker and observe how the values on the Brain's screen change. Placing the disk closer or farther away from the sensor can change the values.
- Even being by a sunny window can change the ambient lighting and affect the Line Tracker values, have students rotate their Workcell to face the Line Trackers from the window or relocate to another spot in the classroom, if possible.
Teacher Toolbox
Check in
Review the following with the group during their check in:
- Ask groups to explain to you what information is displayed on the Brain's screen when using this example project.
- Check that all groups have recorded their high and low values for the Line Trackers in their engineering notebooks.
