Knock The Dispensers
Use [Drive for], [Turn for], and [Spin for] blocks to code the Hero Bot to drive to a blue Dispenser, remove all the Discs from the blue Dispenser, drive to the yellow Dispenser, and remove all the Discs from the yellow Dispenser.
- Select the VIQC Virtual Skills - Slapshot Playground.
- Drive the Hero Bot to a blue Dispenser.
- Code the Hero Bot to spin the Arm Motor to raise the Arm to release the Discs from the blue Dispenser.
- Drive the Hero Bot to the yellow Dispenser.
- Code the Hero Bot to spin the Arm Motor to raise the Arm to release the Discs from the yellow Dispenser.
Helpful Hints
- Each full tile on the VIQC Virtual Skills Field is 300mm by 300mm.
- Use the spin ArmMotor block from the Motion category and select the forward direction to raise the Arm.
- Matching Python command:
- Use the spin ArmMotor block from the Motion category and select the reverse direction to lower the Arm.
