Now that you have practiced using pitch, yaw, and throttle to fly the VEX AIR Drone to different locations, you are ready to combine these skills into a mini-challenge! In this challenge, you will use the VEX AIR Drone Controller to fly the drone in a diamond-shaped flight path. You will apply what you have learned about using data from the Drone Dashboard to … fly with da numbers
