Now that you have practiced using pitch, yaw, and throttle to move the virtual VEX AIR Drone in the VEX AIR Flight Simulator, you are ready to combine these skills in a single mini-challenge! In this challenge, your goal is to apply what you have learned about flying with the VEX AIR Drone Controller to fly through all of the yellow rings in a diamond-shaped path as quickly and accurately as you can.
Mission: Fly in a Diamond
Real-World Connections
Select Return to Units > to move to the next unit in the course.
