Skip to main content
Download and Install VEXcode V5 Factory
Before you begin coding with VEXcode V5 Factory, you must first download the software.
There is a VEXcode V5 application that is specific to the VEX Manufacturing Robotics STEM Labs. This is called VEXcode V5 Factory.
VEXcode V5 Factory
VEXcode V5 Factory is a separate application from VEXcode V5.
VEXcode V5
Since VEXcode V5 Factory and VEXcode V5 are different applications, you can have them both downloaded on your device. One application does not remove, delete, or over-ride another.
VEXcode V5 Factory is available for Windows and macOS.
For more information on how to install VEXcode V5 Factory, view the following install articles for VEXcode V5.
Note: the steps shown in these articles reference VEXcode V5, however, the install process is the same for VEXcode V5 and VEXcode V5 Factory.
