Skip to main content
Practice
In the last section, you learned how the Optical Sensor works and how you can use data from this sensor in your code to have your robot complete a task, such as finding specific colors of Buckyballs. You also learned how control blocks like [If then] and [Repeat] can be used to have your robot make decisions. Now, you are going to apply what you have learned to code your Clawbot with an Optical Sensor to complete the Eye Spy Treasure activity.
In this activity, your robot will drive to two different Buckyballs and use the Optical Sensor to detect the color of each one. If the Buckyball is red, your robot should collect it with the claw and move it to the Home Zone.
Watch the video below to see how you can apply what you have learned to complete the Eye Spy Treasure practice activity.
PLACE HOLDER FOR PRACTICE VIDEO
Now it's your turn to complete the Eye Spy Treasure practice activity!
In this animation, the robot moves autonomously to check each Buckyball with the Optical Sensor, but only picks up the red Buckyball to move it to the Home Zone. Watch this animation to see one possible path your robot could take to complete the Eye Spy Treasure practice activity.
Follow the steps in this document to complete this activity.
PLACE HOLDER ANIMATION
As you complete the Eye Spy Treasure practice activity, document your findings in your engineering notebook.
  • Think about the distances that the robot will need to travel to drive to each of the Buckyballs.
  • Think about what the robot will need to do when it detects a red Buckyball.
View this image for an example of how you can record your results.
PLACE HOLDER ENGINEERING NOTEBOOK
Prepare for the Challenge Activity
In Compete (on the next page), you will code your robot to autonomously check Buckyballs and collect and move only the red Buckyball into the Home Zone. Learn how to compete in the Treasure Mover Challenge, check your understanding, then practice for the challenge.
The goal of this challenge is to have your robot autonomously drive to check the Buckyballs on the Field, and collect the red Buckyball and move it to the Home Zone in the fastest time.
Watch this animation to see an example of how your robot could move in a successful run of the challenge.
This is just one possible path your robot could take to complete the Treasure Mover Challenge.
Follow the steps in this document to learn more about how to complete this activity.
PLACE HOLDER VIDEO
Check Your Understanding
Before beginning the challenge, ensure that you understand the rules and set up by answering the questions in the document below in your engineering notebook.
Check Your Understanding questions >
After completing the questions, practice for the challenge.
Select Next >  to compete in the Treasure Mover Challenge.
