Build
You will now build the Speed Build robot that will be used in this Lesson to play Tag.
Build the robot
Follow along with the video to build the robot, or open the build instructions.
Follow along with this video to build the Speed Build robot.
Document the building process in your engineering notebook.
< video that shows someone actually building the robot on camera >
Or, open the Speed Build Build Instructions and follow along with the steps.
The Speed Build robot has a chassis. The chassis is the structural component for the robot which contains the drivetrain and allows the robot to be mobile by using wheels, tank treads, or another method. A chassis is sometimes referred to as the robot’s frame.
For more information on an IQ chassis, view this article from the Knowledge Base.
< image of chassis called out on the robot >
Select Next > to begin practicing for the the mini-competition.
