Skip to main content
Introduction
Welcome to the VEX AIR Controller Flight Course, where you'll apply what you learned in the Virtual Flight Course to flying the physical VEX AIR Drone indoors, with the VEX AIR Drone Controller. Through safe, deliberate practice, you'll continue building your pilot skills.
In this unit, you'll take your first flight with the physical drone! You'll learn how to prepare your drone and controller, including charging, updating, and pairing. You'll also learn about drone safety and practice your first pre-flight checklist. By the end of this unit, you'll be ready to continue your flying journey with a physical drone.
All of the components in the VEX AIR Kit laid out on a table beside the kit case.
Vocabulary
In this unit, you'll learn how to prepare your drone and controller for flight, practice drone safety and pre-flight procedures, and take off for the first time. The vocabulary list is here to provide reference for key terms you may not be familiar with.
  • Pre-Flight Safety Check — A set of safety steps completed before flying to make sure the drone, controller, pilot, and environment are ready for flight.
  • Takeoff Zone — A clear, designated area where the drone safely lifts off from the ground.
  • Landing Zone — A clear, designated area where the drone safely returns to the ground and the propellers are locked.
  • LED Indicator — A colored light on the drone or controller that shows status information, such as power, connection, or readiness to fly.
  • Propeller Lock — A safety feature on the VEX AIR Drone that prevents the propellers from spinning until the pilot is ready to fly.
  • Emergency Stop (E-Stop) — A control that immediately shuts off the drone’s motors to stop flight during an unsafe or unexpected situation.
Select Next > to move on to the next lesson.
