In this unit, the focus shifts to how the VEX AIR Drone interacts with objects using the Magnet Module. Begin by experimenting with picking up, moving, and delivering magnetic cargo using the drone and VEX AIR Drone Controller. A series of exploration missions will provide you with opportunities to continue building piloting skills with the Magnet Module. This unit also dives deeper to drone maintenance and pre-flight checks, with a focus on inspecting and replacing propellers as needed.
Vocabulary
The key terms below will be useful as you learn about using modules with the drone. The vocabulary list is here to provide you with a reference for terms you may not be familiar with.
- Magnet Module — A module containing a magnet with a mechanized flap to pick up and release objects when the flap is triggered by the controller.
- Payload — The total weight of any equipment (modules) or cargo carried by a drone that is not part of its core operating structure.
- Reticle — A visual marker or crosshair on a screen that helps a pilot line up and aim precisely at a target.
Select Next > to move to the next lesson.
