Skip to main content
Introduction
In this unit, you will explore how the VEX AIR Drone can interact with its indoor environment using modules. The VEX AIR Kit contains three modules — the Passive Module, Magnet Module, and Motorized Hook Module. Over the course of this unit you will be introduced to these modules and explore the Passive Module in detail.
Three VEX AIR Modules from left to right - the Passive Module, Magnet Module, and Motorized Hook Module.
Vocabulary
The key terms below will be useful as you learn about using modules with the drone and VEX AIR Drone Controller. The vocabulary list is here to provide you with a reference for terms you may not be familiar with.
  • Passive Module — A non-powered module containing a magnet and a hook that uses gravity to manipulate objects.
  • Magnet Module — A module containing a magnet with a mechanized flap to pick up and release objects when the flap is triggered by the controller.
  • Motorized Hook Module — A module with a mechanized hook that can be raised or lowered during flight when triggered by the controller.
  • Downwash — The downward airflow created by a drone’s propellers as they push air toward the ground to generate lift.
Select Next > to move on to the next lesson.
