Skip to main content
Introduction
In the last unit, you learned how to use Drone Dashboard data on the VEX AIR Drone Controller to help you understand where your VEX AIR Drone is located when you throttle up and down, pitch forward and back, and roll side-to-side. In this unit, you will learn about heading data on the Drone Dashboard, and how it corresponds to your drone's position when using yaw control, or rotating the drone right and left. Then you will learn how camera views help you navigate as you fly.
The VEX AIR Drone Controller Screen showing the Drone Dashboard, with the center of the screen featuring the drone data like Heading, and x, y, z coordinates for the drone.
Vocabulary
The key terms below will be useful as you build your flight skills with the drone. The vocabulary list is here to provide you with a reference for terms you may not be familiar with.
  • Yaw —  The control that changes how fast opposite pairs of propellers spin to rotate a drone left or right while maintaining the same position in the air.
  • Heading —  The direction the front of the drone is pointing, measured in degrees (0° – 360°).
  • Orientation — The overall position of the drone in space, including its heading and whether it is tilted forward and backward, or from side to side.
  • Headless Steering — A drone control mode where the drone always moves in the direction you push the joystick, no matter which way the drone itself is facing.
  • Standard Steering — A drone control mode where the drone moves based on which direction its nose is facing.
Select Next > to move on to the next lesson.
