Skip to main content
Lesson 1: Combination Movements
Now that you have learned the basics of flying the VEX AIR Drone with the VEX AIR Drone Controller, you are ready to build your skills and combine controls to fly in more complex paths. Each of the missions in this lesson allows you to explore combinations of joystick inputs, as you complete different flight challenges.
In this video, you will learn about:
  • How to use the joysticks to combine controls.
  • How joystick inputs control flight trajectory.
Mission Prep
Real-World Connections
As flights become more complex, drone pilots and engineers rarely use just one control at a time. Real-world drone work depends on combining movements, like rolling while climbing or adjusting speed while turning, to fly smoothly, stay stable, and complete missions accurately. The skills you practiced in this unit are the same foundations used in many drone-related careers.
A man in a flannel shirt holds a drone in one hand as he connects a wire from a computer into the drone, while looking at drone data on the screen.
Drone Flight Programmer or Automation Specialist
These professionals design the software that tells drones how to move smoothly and stay balanced. They create flight algorithms and other automated behaviors by combining movements like roll, pitch, yaw, and throttle to ensure the drone responds correctly in different situations. The work you do combining controls in the simulator mirrors how these specialists approach drone motion.
A drone flies above a field to collect data and visuals about crops being grown. A green cone indicates where the drone is getting data from, while in the foreground a person holds up a tablet showing the field and points to that area with a stylus.
Drone Data Analyst
Drones collect large amounts of data, from images to movement information. Data analysts study this data to identify patterns, measure performance, and inform decisions. Understanding how a drone moves and why it follows certain flight paths helps analysts interpret the data accurately and explain what occurred during a mission.
A drone with a camera rig attached flies over a mountainous landscape capturing video footage.
Drone Cinematographer
Drone cinematographers plan and capture smooth, controlled aerial shots for movies, sports, and documentaries. They design flight paths that require simultaneous multi-axis movements to create steady, cinematic motion. Understanding how combined controls affect drone movement helps ensure the camera captures each shot exactly as planned.
Wrap-Up Discussion
Select Return to Units > to move on to the next unit.
