1725484559
Skip to main content
Identifying Angle Beams
A diagram of VEX IQ angled beams, including 30°, 45°, 60°, and Right Angle (90°) beams, stacked for comparison, to identify and differentiate the angles of the beams.
How to Identify the Different Angles of the Angled Beams
There are four different types of beams that have a bend at an angle: 30o Angle Beams, 45o Angle Beams, 60o Angle Beams, and Right Angle (90o) Beams. There are also three types of Right Angle Beams: 3x5, 2x3, and Offset. The best way to tell which angles are which is to stack the beams on top of each other. Then you can compare how they look. You can also use a protractor to measure the angle of the beam.
