Using the Bumper Switch
The Bumper Switch on Moby can also be used to help complete the challenge in this Lesson —to pick up and move a Mobile Goal to the Alliance Home Zone.
The Bumper Switch is located at the base of the Forks, so that it can be used to determine when a Mobile Goal is ready to be picked up.
For more information about the V5 Bumper Switch, see this Knowledge Base article.
In this example, the Bumper Switch is used to detect when a Mobile Goal is loaded between the Forks.
Once the Bumper Switch reports that it was pressed, Moby will stop driving, lift the Forks to pick up the Mobile Goal, and turn to drive it to the Alliance Home Zone.
Select Return to Lessons > to go back to the Lesson Overview.
Select Next Lesson > to continue to Lesson 3, and learn how to score Preload Rings in a Mobile Goal.
