Skip to main content
Teacher Portal
Answer Key
Summative Assessment Answer Key
  1. Which of the following is the best definition for troubleshooting?
    The process of identifying why something does not work effectively and making suggestions on how to improve it.
  2. True or False: The addition of standoffs to the Workcell can help improve the flow of disks.
    True
  3. Which of the following is used in a project to not only help organize the code, but also allows a user to plan out the overall goal of the project before beginning?
    Comments and notes
  4. True or False: The V5 Battery can operate while it is charging.
    True
  5. Which of the following should be used in order to properly lubricate the Turntable on the V5 Workcell?
    White lithium grease
