In this lesson, you will learn how to use the Motorized Hook Module on the VEX AIR Drone to pick up objects in the VEX AIR Flight Simulator. You will practice lowering and raising the motorized hook to grab an orbit ball and lift it safely off the ground. Using the motorized hook requires careful alignment and steady control.
You will also begin to notice how carrying an object below the drone affects flight. By the end of this lesson, you will be able to align the drone and transport an orbit ball using the VEX AIR Drone Controller.
Watch the video to learn more about:
- How the Motorized Hook Module works.
- Lowering and raising the motorized hook using the controller.
- Aligning the drone to pick up an orbit ball.
Hover & Discover
When a drone flies through the air, it experiences drag, which is a force that pushes against moving objects. Drag increases when a drone carries a suspended payload, like an orbit ball hanging below the drone. The payload adds extra surface area, giving the air more to push against.
Because of this added drag, drones carrying suspended objects respond more slowly to control inputs. Pilots must make smoother, smaller movements to stay stable. Flying too quickly can cause the payload to swing, making the drone harder to control.
Mission: Pick Up and Deliver an Orbit Ball
Check Your Understanding
Select Next > to move to the mini-challenge.
