Skip to main content
Introduction
In this unit, you will expand your piloting skills by using the Motorized Hook Module to pick up and transport objects in the VEX AIR Flight Simulator. You will explore how to control the hook using the VEX AIR Drone Controller in order to pick up and deliver orbit balls on the field. All of your practice will culminate in a mini-challenge to showcase your precision piloting!
VEX AIR Drone in the simulator on the Competition field. The drone is carrying a orbit ball and appears to be headed to a goal.
Vocabulary
In this unit, you will take your first flight! The vocabulary list is here to provide reference for key terms you may not be familiar with.
  • Motorized Hook Module — An attachment on the drone that uses a motor to raise and lower a hook for picking up and releasing objects during flight.
  • Orbit Ball — A lightweight ball used in the simulator that the drone can pick up, carry, and drop using the Motorized Hook Module.
  • Suspended Payload — An object that is hanging below the drone while being carried, instead of being attached directly to the body of the drone.
  • Drag — Forces that oppose the relative motion of an object through the air.
Select Next > to move to the next lesson.
