Now that you have been introduced to using the Motorized Hook Module on the VEX AIR Drone to pick up and drop orbit balls, you are ready to transport them to different locations around the Competition layout in the VEX AIR Flight Simulator. In this mini-challenge, your goal is to use the motorized hook to pick up and deliver three orbit balls with the VEX AIR Drone Controller. You will deliver one to a Drop Zone, one to a Drop Tower, and one to the Pole.
Scoring Locations in the Competition Layout
There are three locations where orbit balls can be scored in the Competition layout in the simulator.
| Drop Zone | Drop Towers | Poles |
- Drop Zone — The long trough-like open structure between the two platforms.
- Drop Towers (1 red and 1 blue) — The tall funnel-like structures located on the far left and right corners of the field, opposite the platforms.
- Poles (1 red and 1 blue) — The tall stick-shaped goals located in front of each platform.
Mission: Ball Drop
Real-World Connections
In the real world, drones often use hooks, cables, or lines to lift and retrieve objects that cannot be picked up directly and require using a suspended payload.
Search-and-rescue teams use drones with hooks to lower supplies like rope, radios, or medical kits to people in hard-to-reach locations. This allows help to arrive quickly without putting rescuers in danger.
Just like in the simulator, pilots carrying suspended payloads must carefully align the drone and move slowly to keep the object stable. Learning how to control a drone with a hanging load helps prepare pilots for real-world missions that require precision, patience, and safety.
Select Return to Units > to move on to the next unit.
