Using a Different Hero Robot
The Village Engineering Construction VEX GO Competition STEM Lab Unit is a great way for to students to explore the idea a robotics competition, to build on what they have learned and done with VEX GO, and to extend STEM learning in fun and engaging ways. The Village Engineering Construction Competition STEM Lab Unit is written using the Competition Advanced 2.0 Hero Robot to put the focus of the activities on the Field tasks themselves, rather than the different robot builds. The Competition Advanced 2.0 Hero Robot is capable of completing all tasks on the Field, however, this Unit can be adapted to use other Hero Robots as well. The Hero Robots themselves have varying levels of complexity, enabling you to use the robot that best meets the needs of your students.
Competition Base 2.0 Hero Robot
This is the base competition Hero Robot. This Hero Robot, similar to the Code Base, is the easiest and quickest for students to build. It is a great introductory competition robot for students to quickly begin engaging in VEX GO competition tasks.
To build the Competition Base 2.0 Hero Robot, follow the PDF Build Instructions or the 3D Build Instructions here. All Competition Hero Robots begin with the Competition Base, then add onto it with other components to add complexity.
Competition Base 2.0 + Claw Hero Robot
This build has students add a claw to the Competition Base 2.0 Hero Robot. This claw allows students to complete some more complex tasks.
To build the Competition Base 2.0 + Claw Hero Robot, build the Competition Base first, then use the PDF Build Instructions or 3D Build Instructions to add the Claw.
This is the most complex Hero Robot build, adding a moveable robotic arm that can be used to raise and lower objects. The arm is controlled with an additional motor. This robot allows students to complete all competition tasks.
To build the Competition Advanced 2.0 Hero Robot, build the Competition Base first, then use the PDF Build Instructions or the 3D Build Instructions to add the arm.
Adapting the tasks in this Unit to use other Hero Robots
The Village Engineering Construction Competition is adaptable for any of the Hero Robots. While it is written using the Competition Advanced 2.0 Hero Robot, you can adapt the tasks in this Unit to best meet the needs of your students. To use different Hero Robot builds, adjust which tasks are included in the classroom competitions for each Lab, and the culminating competition for the Unit.
This table shows which tasks in each Lab can be completed with each of the Hero Robot builds.
Village Engineering Construction Competition Tasks
Lab # | Task | Competition Base | Competition + Claw | Competition Advanced |
#1: Village Construction | Remove house components from trailer | X | ||
#1: Village Construction | Deliver house components to red tile | X | X | X |
#1: Village Construction | Stack delivered house components on red tile (human task) | N/A | N/A | N/A |
#2: Expand the Village | Rotate wind turbine into position | X | X | X |
#2: Expand the Village | Lower bridge | X | X | X |
#3: Water Transit | Remove water pipe from trailer | X | ||
#3: Water Transit | Move water pipe to water tower tile | X | X | X |
#3: Water Transit | Lift the water tower upright | X | X | X |
#4: Farm to Table | Deliver crops to food processor tile | X | X | X |
#4: Farm to Table | Press down on food processor to produce food | X | ||
#4: Farm to Table | Deliver food to red tile | X | X | X |
The competitions for each Lab, and the Unit competition can feature any of the tasks in the table above. Depending on the Hero Robot that your students are using, you may want to adjust the tasks that are offered in the competitions. You can decide whether you want all students to use the same Hero Robot, or if you want to give students the option to choose which Hero Robot they wish to use for the Unit competition in Lab 5, and adjust the tasks on the Field accordingly.
