Skip to main content
Teacher Portal
Design Your Build
Answer the following questions in your engineering notebook as you design your build.
  1. What do you want the build to do? Explain specific actions.
  2. How do you plan on testing your build? Explain with details.
  3. What will you do to ensure your build is capable of completing the desired task(s)? Explain with details.
Test and iterate on your build.
  1. What were some things you discovered in your testing that you did not expect? Explain with details.
  2. How did you improve your build based on your test results? Explain with details.
  3. Is there a change you would like to make but need additional pieces? Explain with details and/or sketches.
