Skip to main content
Change targetY
  1. Remove the (Add) block from the ‘x’ parameter in the [Linear move] block by dragging it into the workspace.
    Remove add block
  2. Place the ‘targetX’ variable back into the ‘x’ parameter of the [Linear move] block.
    Replace targetX variable
  3. Move the ‘targetY’ variable from the ‘y’ parameter of the [Linear move] block to the (Add) block.
    Move targetY to add
  4. Place the (Add) block into the ‘y’ parameter of the [Linear move] block.
    Move add to Y
  5. Download and run the project.
    Download and run
    Note: if the dry-erase marker is not drawing well, adjust the z-axis values to provide more force.
  6. Observe that the arm mounted on the VEX V5 Workcell drew a straight line (linear motion) one inch along the y-axis.
    y1
  7. Stop the project.
    Stop the project
