Skip to main content
Repeating Variables
To change variables by a constant increment, a [Repeat] block can be used. A [Repeat] block is useful to repeat blocks for a fixed number of times. For more information about the [Repeat] block, view the Help for VEXcode V5 article from the Knowledge Base.
In the following steps, [Change variable] blocks will be used to increment the movement of the arm mounted on the VEX V5 Workcell by constant values.
  1. Remove the (Add) blocks from the [Linear move] block.
    Remove all add blocks
  2. Select and drag the [Change variable] block from the ‘Variables’ category in the Toolbox and attach it to the [Linear move] block.
    Add change variable block
  3. Change the variable of the [Change variable] block to ‘targetX.’
    Parameter of Change variable
  4. Repeat steps 39 and 40 to add another [Change variable] block for the variable ‘targetY’ to the first [Change variable] block.
    Change variable X and Y
    Note: a [Change variable] block is not added for the variable ‘targetZ’ because if that variable was changed, the dry-erase marker would not draw properly along the z-axis.
  5. Add a [Repeat] block around the [Linear move] and [Change variable] blocks to repeat those three blocks a set number of times.
    Add repeat block
  6. To move the arm mounted on the V5 Workcell along the x and y-axis in three increments, set the parameter of the [Repeat] block to ‘3.’
    Change repeat to 3
    Note: a [Wait] block can be added after the [Change variable] blocks to observe the change in increments at a slower pace if desired.
  7. Download and run the project.
    Download and run
    Note: if the dry-erase marker is not drawing well, adjust the z-axis values to provide more force.
  8. Observe that the arm mounted on the V5 Workcell drew a straight diagonal line (linear motion) in three-one inch movements along the x and y-axis.
    xy3
