1601420084
Skip to main content
Teacher Portal
Implementing VEX GO STEM Labs
STEM Labs are designed to be the online teacher’s manual for VEX GO. Like a printed teacher’s manual, the teacher-facing content of the STEM Labs provides all of the resources, materials, and information needed to be able to plan, teach, and assess with VEX GO. The Lab Image Slideshows are the student-facing companion to this material. For more detailed information about how to implement a STEM Lab in your classroom, see the Implementing VEX GO STEM Labs article.
Goals and Standards
Goals
Students will apply
  • How to use the VEX GO Kit’s components in a build.
Students will make meaning of
  • How to identify that pins and standoffs are used to connect VEX GO pieces.
  • How to manipulate the kit materials safely and effectively when building.
Students will be skilled at
  • How to assemble and detach components using pins and the Pin Tool.
  • How to identify and use pins, standoffs, beams, and plates.
Students will know
  • How to assemble and detach VEX GO connectors and components.
  • How to identify VEX GO pieces and their functions.
Objective(s)
Objective
  1. Assemble and disassemble pieces from the VEX GO Kit.
  2. Explain that pins and standoffs are used to attach components.
Activity
  1. Students will practice manipulating the pieces from the VEX GO Kit to build a structure during Play Part 1.
  2. Students will explain how they utilized standoffs and pins in their build, during informal and formal discussions.
Assessment
  1. Students will build a flagpole for their Astronaut, using only provided pieces from the VEX GO Kit in Play Part 2.
  2. Describe their build and design process using part names, descriptions and functions during informal and formal discussions.
Connections to Standards
