1724877257
Skip to main content
Removing a Robot Battery
In this section you will remove the Robot Battery from the Robot Brain.
Materials Required:
Quantity Materials Needed
1
Robot Battery
1
Robot Brain
Removing a Robot Battery Instructions
Step 1: Removing the Battery
Diagram with arrows indicating pressing down the latch on a Robot Battery and pulling it away from the Brain to remove it.
Removing the battery from the Robot Brain
To remove the Robot Battery from the Robot Brain, you must press the latch down while pulling the Robot Battery out.
Conclusion:
In this section you removed the Robot Battery from the Robot Brain. It is recommended that you do not leave the battery inside the Robot Brain for an extended period of time. Click here for best practices for preserving the battery's life.
