1724873609
Skip to main content
San Francisco and Seismic Isolators
Aerial view of San Francisco, an earthquake-prone area, showcasing various buildings designed with seismic isolation.
San Francisco, in the United States of America
Illustration showing the difference between conventional structures, prone to severe shaking; and seismic isolation structures. The flexible bearings of a seismic isolation structure allow a building to move horizontally during an earthquake to enhance safety by reducing shaking impact.
Normal buildings are not designed to withstand shaking. Adding seismic isolation makes them sturdier in an earthquake.
Seismic isolation helps prevent major catastrophes!
Conventional buildings are constructed with the foundation laid right into the ground. Buildings built this way will shake with the earth if an earthquake occurs there. This would cause extensive damage due to the severe shaking motion.
Seismic isolation (or base isolation) is when the building is built on top of pads or flexible bearings. When the building is built this way, the building structure is resting away from the ground. This allows the entire building to move in a slow horizontal motion during earthquakes. Reducing the shaking makes the building safer and sturdier in an earthquake.
Many cities in the world commonly have earthquakes, such as San Francisco. Builders there design buildings to use base isolators to make them safer. Even though this costs more money to do, the added safety is worth the cost.
