1724776332
Skip to main content
Getting Ready to Code
There are built in resources in VEXcode IQ available to help you get started coding. You can access Tutorial Videos, Help, or Example Projects to learn more about things like saving, downloading, and running your project, how to use a specific block, or getting started with a project.
Tutorial Videos
To access tutorials, select the 'Tutorials' icon in the VEXcode IQ Toolbar, as shown here.
The following tutorial videos may be helpful to get started with this Unit:
  • Getting Started
  • Device Setup - Drivetrain
  • Naming and Saving Your Project
  • Download and Run a Project
VEXcode IQ Toolbar with the Tutorials icon called out in a red box, to the right of the File menu.
Built-in Help
To access Help, select the 'Help' icon in VEXcode IQ, as shown here.
Then, select a block or command to learn more about it.
The Help feature offers block or command-specific information, including things like how they can be used in a project.
VEXcode IQ Toolbar with the Help icon called out in a red box, to the right of the Configuration.
Example Projects
To access Example Projects, select 'File', then 'Open Examples', as shown here.
For a beginning project to help you get started coding, you can use an Example Project. Example Projects include Templates for different VEX IQ builds, as well as sample projects for a variety of features and functions.
In this Unit, the following Template example project can be used:
  • Basebot (Drivetrain 2-motor)
VEXcode IQ Toolbar with the File menu open, and Open Examples selected with a red box. 'Open Examples' is the fourth item in the menu, beneath 'New Blocks Project', 'New Text Project', and 'Open'.
What is Next?
In this Lesson, you built the BaseBot and charged your Battery.
In the next Lesson, you will:
  • Learn about how balanced and unbalanced forces affect the movement of your robot.
  • Create a rope attachment for your BaseBot.
  • Compete in the Robot Tractor Pull challenge!
BaseBot on a Field with a rope attachment connecting an IQ Kit to it, with an arrow indicating the robot's forward movement in the Robot Tractor Pull Challenge.
Select < Return to Lessons to go back to the Lesson Overview.
Select Next Lesson > to continue to Lesson 2, and learn about how forces affect the motion of your robot.
