Skip to main content
Answer Key
Summative Assessment Answer Key
  1. Which of the following is NOT a troubleshooting technique when the VEX V5 Workcell is not working?
    Remove all of the Smart Cables from the arm mounted on the VEX V5 Workcell
  2. True or False: The addition of standoffs to the Workcell can help improve the flow of disks.
    True
  3. Which of the following is used in a project to not only help organize the code, but also allows a user to plan out the overall goal of the project before beginning?
    Comments and Notes
  4. True or False: The V5 Battery can operate while it is charging.
    True
  5. Which of the following should be used in order to properly lubricate the Turntable on the VEX V5 Workcell?
    White lithium grease
