Answer Key
Summative Assessment Answer Key
- Where can you check to find out if the V5 Brain has updated firmware?
The green brain icon in the Toolbar. - What is the purpose of the Mastering Jig?
To ensure that the arm mounted on the VEX V5 Workcell is in the correct position to obtain the mastering values. - Which joint does the motor identified below control?
Joint 4 - Which of the following is NOT a reason to determine the mastering values for the V5 Workcell?
To ensure the V5 Brain is charging. - True or False: when mastering values, if any joint fails, two things should be done in order to pass:
- Check if the potentiometers need to be adjusted. Refer back to the Lab 1: Build Instructions to ensure that the potentiometers were added and oriented correctly.
- Ensure all devices are fully inserted into the correct V5 Smart Ports on the V5 Brain.
True
