Skip to main content
Answer Key
Summative Assessment Answer Key
  1. Which of these is best described as something “used to store values in a project?”
    Variable.
  2. Based on this project, how will the arm mounted on the VEX V5 Workcell move from the start coordinate of (0, 0, 1.5)?
    In a straight line with x-values increasing.
  3. Based on this project, how will the arm mounted on the VEX V5 Workcell move from the start coordinate of (0, 0, 1.5)?
    Diagonally with x-values and y-values increasing.
  4. Based on this project, how will the arm mounted on the VEX V5 Workcell move from the start coordinate of (0, 0, 1.5)?
    In a straight line with y-values decreasing.
  5. Why is an (Add) block not used with the z-axis in this project?
    Adding to the z-axis would lift the marker off of the whiteboard.
