Skip to main content
Robot Battery Charging and Usage
In this section you will learn about assembling the Robot Battery Charger and charging the Robot Battery.
Materials Required:
Quantity Materials Needed
1
Robot Battery Charger 228-2743
1
Robot Battery Charger Power Cord appropriate for your region
1
Robot Battery 228-2604
Step 1: Connecting the Cord
A Diagram Showing a Robot Battery Charger Power Cord Connecting To a Robot Battery Charger
The Robot Battery Charger Power Cord connects to the Robot Battery Charger
Connect the Robot Battery Charger Power Cord to the Robot Battery Charger.
Step 2: Plugging in to an Outlet
A Diagram Showing a Robot Battery Charger Power Cord Connecting To a Wall Power Outlet
The Robot Battery Charger Power Cord connects to a wall power outlet
Plug the other end of the Robot Battery Charger Power Cord to a power outlet.
Step 3: Charging the Robot Battery
A Diagram Showing a Robot Battery Sliding Into a Robot Battery Charger
The Robot Battery sliding into the Robot Battery Charger
Slide the Robot Battery into the cradle of the Robot Battery Charger. You should see the light change to red to indicate that it is charging.
Conclusion:
Once the Robot Battery Charger is connected to a power outlet, the Robot Battery can be charged. It may take a few hours to fully charge.
