Skip to main content
Programming Loops - C++
The Clawbot V5 is ready to move!
This exploration will give you the tools to be able to start creating some cool projects that use loops.
  • VEXcode V5 instructions that will be used in this exploration:
    • Drivetrain.driveFor(forward, 300, mm);
    • Drivetrain.turnFor(right, 90, degrees);
    • ClawMotor.spinFor(reverse, 70, degrees);
    • ArmMotor.spinFor(forward, 360, degrees);
    • while (true) {}
    • repeat (4) {}
    • wait(5, seconds);
To access additional information, right click on a command name in your workspace to see help for that command.
Make sure you have the hardware required, your engineering notebook, and VEXcode V5 downloaded and ready.
Materials Required:
Quantity Materials Needed
1
VEX V5 Classroom Starter Kit (with up-to-date firmware)
1
VEXcode V5 (latest version, Windows, macOS)
1
Engineering Notebook
1
Clawbot Template (Drivetrain 2-motor, No Gyro) example project
Step 1:  Let's start programming with loops
  • Before you begin your project, select the correct template project. The Clawbot Template (Drivetrain 2-motor, No Gyro) example project contains the Clawbot's motor configuration. If the template is not used, your robot will not run the project correctly.
    Image showing the File menu open in VEXcode V5 showing the Open Examples option
  • Select File and Open Examples.
  • Scroll through the different Example projects. These projects demonstrate a variety of actions your Clawbot can perform. Select and open the Clawbot Template (Drivetrain 2-motor, No Gyro) example project.
  • Name the project RepeatingActions.
    Image showing the Repeating Actions project name in VEXcode V5
  • Type the following code:
    int main() {
      // Initializing Robot Configuration. DO NOT REMOVE!
      vexcodeInit();
      // Drives forward and turns 90 degrees for 4 iterations
      repeat(4){
        wait(5, seconds);
Look over the project and then do the following in your engineering notebook.
  1. Predict what the project will have the Clawbot do. Explain more than the fact that the project repeats.
    What is it repeating? What is the Clawbot doing?
  2. Write your prediction, but do not break the short project into more than two parts.
  • Save, download, and run the Repeating Actions project.
    Image of the Repeating Actions project name in the Toolbar in VEXcode V5
  • Check your explanations of the project in your engineering notebook and add notes to correct them as needed.
Step 2: Run the project and observe the robot
A comparison of two C++ code snippets in VEXcode. The left snippet uses sensor input to determine when to turn, with a while loop that checks if the bumper switch is pressed; if pressed, the robot turns right 90 degrees, otherwise, it drives forward. The right snippet uses a fixed distance to determine when to turn, with a repeat loop that drives the robot forward for 300mm, turns right for 90 degrees, and waits for 5 seconds, repeating this sequence four times
Look at the Repeating Actions project (on the right) again. This project will repeat the forward and then turn behavior four times. A "repeat" loop structure is used when you want to use a set of behaviors a certain number of times.
If the repeat structure is replaced with a "while" loop structure, the robot will repeat the forward and then turn behaviors "while" the condition is true. You can also set the condition to "true" to have the "while" loop continue forever.
In the project on the left, a sensor's input is used to determine when to begin turning. The project on the right uses a fixed Drivetrain distance to determine when to begin turning.
In order to continually check a sensor's input, an "if/else" statement is used together a "while" loop. In the project on left, the robot will turn right when the "BumperB" sensor is pressed, otherwise the robot will drive forward forever if the "BumperB" sensor is not pressed. To continually check the BumperB sensor's value, the "if" statement is within a "while true" loop.
The above project on the left is a practical use-case of a structure that repeats forever - using while loops and if statements together. Imagine a self-driving sweeper that continues to drive forward until it runs into a wall or object, then turns before continuing to drive.
Step 3: The Squared Loops Challenge!
A diagram showing a green square pathway with arrows indicating the direction of movement around the square. Additional orange arrows outside the square point in different directions, corresponding to the turns and movements required to follow the pathway
  • Have your Clawbot drive in a square.
  • Before each turn, the claw must be opened and closed, and the arm must be raised and lowered.
  • The Clawbot cannot drive along a side of the square more than once.
  • You can use the RepeatingActions project from above as a starting point but save it as SquaredLoops before making any changes.
Image of the Squared Loops project name in the VEXcode V5 Toolbar
In your engineering notebook, plan the following:
  • Plan out your solution and predict what each instruction in your project will have the Clawbot do.
  • Download and run your project to test it before submitting it.
  • Make changes to the project as needed and take notes about what was changed during testing.
