Build Instructions
Teacher Tips
Notice that the parts listed are not scaled 1:1. They are relatively scaled to one another.
Keep an eye out for the blue coloring on the ends of the screws as this indicates which screws are locking and non-locking. It also helps to differentiate between different lengths of screws.
Notice that the Smart Cable's length is printed at the base of each connector end.
Build the Speedbot
Follow along with the build instructions to build the Speedbot.
Open and follow along with the steps to build the VEX V5 Speedbot.
Build Instruction Tips
Check the Appendix for info on how to use the new Hex Nut Retainers.
Teacher Tips
Organize students into groups of two or three to construct the Speedbot. The build will take students approximately two hours to complete.
Allow students enough time at the end of the class period to note their progress in their engineering notebooks and clean up their area.
Teacher Toolbox
The names and quantities of the parts needed for each step can be found at the bottom left of the image.
The actions to complete the step are in the center.
The completed look of the build per step is in the red rectangle.
Select the image to enlarge it.
