Build Instructions
Teacher Tips
Notice that the parts listed are not scaled 1:1. They are relatively scaled to one another.
Keep an eye out for the blue coloring on the ends of the screws as this indicates which screws are locking and non-locking. It also helps to differentiate between different lengths of screws.
Notice that the Smart Cable's length is printed at the base of each connector end.
Follow along with the build instructions to build the Clawbot.
Open and follow the steps to build the VEX V5 Clawbot.
Build Instruction Tips
Check the Appendix for information on how to use the new Hex Nut Retainers.
Teacher Tips
Organize students into groups of two or three to build the V5 Clawbot. The build takes approximately 2 hours and 30 minutes to complete.
Allow enough time at the end of the class period for students to note where they left off in their engineering notebooks and clean up their area.
Teacher Toolbox
The names and quantities of the parts needed for each step can be found at the bottom left of the image.
The actions to complete the step are in the center.
The completed look of the build per step is in the red rectangle.
Select the image to enlarge it.
