The Completed Look of the Build
Teacher Tips
Use this image as a point of reference to verify if students assembled the V5 Clawbot correctly. The build takes approximately 2 hours and 30 minutes to complete.
Allow students enough time at the end of the class period to note where they left off in their engineering notebooks and clean up their area.
The VEX V5 Clawbot is an extension of the VEX V5 Speedbot that can be programmed to move around and interact with objects.
Teacher Toolbox
The Seek section of the STEM Lab guides students through building the robot needed for the rest of the lab. If you or your students have already built this robot and have gone through the questions on the Exploration page, you can skip down to the Play section of this STEM Lab and continue from there.
